Szevasztok,newezett HI-FI vel kűzdök,nincs kapcsolási rajzom,a végfok megy,de a TC 9213P toshiba Ic-nél megállt a tudomány.Nem találok róla adatlapot!Ha valaki tudna segíteni,kapcsolási rajzzal,vagy IC adatlappal,sokat segítene.Üdvözlettel:oivan
Hozott egy jó barátom egy ilyen autórádiót amiben szétégett egy ic.
Sehol nincs ilyen még ebay-en sem találtam ( nec 784225GC281 ).
Kéne egy bontott ugyanilyen amiből ki lehetne termelni.
Üdv: Peti
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Kaptam egy ilyen erősítőt ingyen, hogy ha akarom akkor rakjam össze magamnak. Az előző -szakértő- tulajdonos kicserélt benne jópár kondenzátort de valami savval forrasztott, ennek következtében úgy nézett ki a panel alja, mintha lehányták volna. Miután újraforrasztottam az egészet...eltüntettem pár rövidzárat...áthidaltam pár szakadást nem vettem észre, hogy a végfok ic + és - tápját is sikerült összefolyatni a szakinak, így bekapcsolást követően egy meglehetősen nagy csattanással megszűnt a zárlat. A gép egyébként bekapcsolt, csakhogy pár másodperc után elkezdett füstöni a trafója. Miután lekötöttem mindent a trafóról utána is elkezd búgni és füstölni... A kérdés, hogy vajon megéri-e szerezni új trafót, vagy inkább kuka? Egyébként kb. 150-200W-os a trafó 2x43V, 2x15v, 6v, 12v tekercsek vannak rajta.
