KENWOOD KT-3300D SCH
1.8 MB
KENWOOD KT-3300D SCH service manual (1st page)
Preview of KENWOOD KT-3300D SCH [1st page]
KENWOOD KT-3300D SCH service manual (2nd page)
Preview of KENWOOD KT-3300D SCH [2nd page]
    KENWOOD KT-3300D KT3300D KT 3300 3300D
KENWOOD KA-4050R service manual
Because I did not found it and I was forced to buy, you get it for free!
https://mega.nz/#!RlpCxCRQ!zhVCwJnC3dDiYlJSmDqRMOVeLzL7soairMfFxsup61A
Kenwood, KDC-W7041U autórádió
Sziasztok! Kérem segítségeteket, egy Kenwood KDC-W7041U típusú autórádió gyári kódjának megállapításához! szériaszám:KE1487W0201154 Köszönettel: remi
Kenwood A-7 X Rajz
Üdvözlet minden fórumozónak. A témában említett készülék rajzára lenne szükségem, mert a tulaj belebarmolt és egy pár ellanállat szénné égett a kísérletezése közben amit nem tudok beazonosítani. Ha valakinek lenne esetleg, kérem rakja fel az oldalra vagy írja meg nekem hogy honnan tudnám leszedni. Segítségeteket előre is köszönöm. Irkax.
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
