I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Szevasztok,newezett HI-FI vel kűzdök,nincs kapcsolási rajzom,a végfok megy,de a TC 9213P toshiba Ic-nél megállt a tudomány.Nem találok róla adatlapot!Ha valaki tudna segíteni,kapcsolási rajzzal,vagy IC adatlappal,sokat segítene.Üdvözlettel:oivan
Ebayen nemrég vettem egy fent említett fejegységet.
Első bekapcsolás után kiderult, hogy egy CD be van ragadva, ki sem próbálja adni, lejátszáskor el sem indul. Az USB-ről lejátszás ekkor még ment.
Elsőként próbáltam resetelni, nyílván semmi eredménnyel, majd service mode-ban factory reset (Next+ATT+Reset gombok, SM-ben 21.oldal)
Itt hibát nem írt ki, C D _ E 2 P: O, valamint A U D I O _ E 2 P : O, ami jót jelent.
Ezután atomjaira szedtem a CD mechanikát, majd összerakás után tökéletesen beveszi-kiadja a CD-t.
Sajnos viszont a lejátszás nem indul el, "Mecha error" hibát dob a kijelzőn. Most már USB-ről lejátszásra szintén ugyan ez a hiba.
Amire gondolok, hogy a gondot okozhatja, az az, hogy a unique ID-t is törölte a reset (8 byte-os azonosító), amivel elvileg párosítva van a CD mechanika a fő egységhez.
Egy hasonló modell (MP928) SM-jából kiderül (18.oldal), hogy ezt az ID-t elvileg az előlapról be lehet állítani, és ilyenkor az IC17-ben tárolódik (a CD mechanika egységen). Ha jól sejtem, ennek az ID-nak a tunerben lévő EEPROM-ban is benne kéne lennie, mert azzal hasonlítja össze?
Amugy az EEPROM ha jól sejtem piszkálva volt korábban, mert security CODE-ot sosem kér, és be sem lehet állítani.
Van ötletetek rá, hogy a Unique ID-t hogyan lehetne kiszedni, és beállítani?
(Még annyit, hogy az SM szerint a CD mechanikára rá van ragasztva ez az ID, de én nem találtam ilyet)
Előre is köszönöm!
Kogabe
Meggyűlt a bajom ezzel a készülékkel, így minden építő jellegű tanácsot szívesen fogadok.
Jelenség, hogy max.hangerőre tekerve is csupán alig hallható. Minden bemenetnél és saját rádióról. Próbálgatás során egyszer (megbontás előtt) majdnem tökéletes volt, ezért kontakthibára gyanakodtam. Szétszedtem és alaposan átforrasztottam minden esetleges hibaforrást, valamint átértem az alkatrészeket. "természetesen" a helyzet nem változott. Amiket kiokoskodtam feszültségeket azokat ellenőriztem és rendben vannak. Sajnos csak szétszerelt állapotban lehet rendesen hozzáférni..
Tehát most ismét ott tartok, hogy nagyon halk. Némítás működik és minden más funkció szabályoz. Magas, mély, hangszórók (front, center, stb) szintje is állítható csakúgy, mint az előre programozott hangzások.
Valakinek tapasztalata/tippje mi okozhat ilyen jelenséget?
Köszönettel: Kiss Z.
http://stereo.ru/before/images/profile/14396/img_big0.jpg
