Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Sziasztok!, nem rég olcsón meg vásároltam egy KENWOOD KA-5050R típusú erősítőt, a régi gazdája sajnos tönkre tette mind a két végfok-ját!. Ennek az erősítőnek a vég tranzisztorai 2SK1529, és 2SJ 200-as végtranzisztorokból áll, a kérdésem pedig az volna hogy ezeket a típusú tranzisztorokat milyen típusú tranzisztorokkal lehet még helyettesíteni?, ugyan is az összes végtranzisztor zárlatba ment!, és ezek a típusú tranzisztorok nagyon drágák, és egy kis seb vagyonba kerülne az erősítő újra élesztése, mivelhogy a 2SJ 200-as és a 2SK 1529-es ből 4-4 darab kell!. Ha valaki tudja mivel lehet még helyettesíteni ezeket a típusú tranzisztorokat azt kérem segítsen, és ha valakinek meg van a kapcsolási rajza az erősítőnek az is sokat segítene, mert még van négy darab ellenállás is ami oly annyira meg éget hogy a színkódot nem lehet le olvasni az ellenállásról, csak az első szint sikerült be azonosítanom ami a szürke szín. A négy ellenállás teljesen meg szakadt, le kapartam az ellenállásokról a védő réteget, hogy hátha le tudom mérni az ellenállást, a mérő műszer egyik mérő tuskéjét rá csatoltam az ellenállás egyik végére a másik mérő fejt pedig húztam felfele az ellenállás szén rétegén és ezeket az értékeket kaptam ahogy mentem felfelé 75ohm, 114ohm, 420ohm között mozogtak az értékek, én szerintem 820ohm-osak lehetnek az ellenállások, de nem vagyok benne biztos. Az ellenállások pozíció száma pedig a köv- R29, R30, R31, R32. Amúgy ezek az ellenállások a meghajtó tranzisztorok bázisait csatolja össze. A meghajtó tranzisztorokból van két darab 2SA 1535 aminek a C-ra, és a E-je össze csatlakozik a B-uk pedig csatlakozik ezeken az ellenállásokon keresztül a két másik 2SC 3944-es tranzisztor B-saira, és ezeknek a C-ra és az E-re is közös. Köszönöm!.
Fent nevezett géppel az a probléma,hogy nem megy rajta az RDS,kérdésem az lenne,találkozott-e vki ilyen hibával,másrészt,ha jól látom az RDS IC:LC72723,tud-e vki bizos beszerzési forrást,a HQ-nál nem is ismerik,az ASWO ismeri de 0db van mindenhol.
Üdvözlettel
Vadászy Gábor
Meggyűlt a bajom ezzel a készülékkel, így minden építő jellegű tanácsot szívesen fogadok.
Jelenség, hogy max.hangerőre tekerve is csupán alig hallható. Minden bemenetnél és saját rádióról. Próbálgatás során egyszer (megbontás előtt) majdnem tökéletes volt, ezért kontakthibára gyanakodtam. Szétszedtem és alaposan átforrasztottam minden esetleges hibaforrást, valamint átértem az alkatrészeket. "természetesen" a helyzet nem változott. Amiket kiokoskodtam feszültségeket azokat ellenőriztem és rendben vannak. Sajnos csak szétszerelt állapotban lehet rendesen hozzáférni..
Tehát most ismét ott tartok, hogy nagyon halk. Némítás működik és minden más funkció szabályoz. Magas, mély, hangszórók (front, center, stb) szintje is állítható csakúgy, mint az előre programozott hangzások.
Valakinek tapasztalata/tippje mi okozhat ilyen jelenséget?
Köszönettel: Kiss Z.
http://stereo.ru/before/images/profile/14396/img_big0.jpg
