Nevezett készülék indítást követően pár másodperc után lekapcsol a védelem miatt. Több hiba is volt a masinában amit javítottam. 5V-os stabilizátor, 12V-os. "nagy táp" sem volt meg ami a graetz cseréje után helyreállt. Jelenleg már szimmetrikusak a feszültségek -12v/+12v ill. -40v/+40v (3-4 tízed eltéréssel)
Végfokoknál sem találtam mérhető hibát, kimeneteken sincs egyen. Természetesen "földelés" összezárva. 3.3V és 2.5V is rendben.
Hozzá(bb) értőktől kérdezném, miként lehetne kideríteni okát a védelem bekapcsolásának?
Köszönettel: Kiss Z.
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Tisztelt Szakik!
Egy ismerősöm fordult hozzám ezzel a kéréssel, hogy milyen módon (módokon) lehet ezt itthon beüzemelni.
Kiindulási alap hogy a legegyszerűbben és a legolcsóbban.(meg persze legyen üzembiztos)
Ehhez kérnék tippeket.
Amerikai eredetű készülék, 120V 60Hz, rajza a itt a tanyán, 13 oldal a táp rész.
Köszönettel D A
Üdv minden kedves fórumtársnak!
Adott egy Kenwood KRF-V4080D készülék. A kérdésem az lenne, hogy valamilyen módon nem-e állitható benne a hangszin távirányitó nélkül? Sajnos elkallódott a távvezérlője, és a kézikönyv leirása szerint (Csak távvezérlővel) lehet a hangszint állitgatni. Valami tipp esetleg ötletet tudtok adni mit tudnék tenni? Csak mert nem tűnik egy rossz szerkezetnek.
