Kapcsolási rajzot keresek az alábbi típushoz :
Kenwood KRF-V070D erősítő.
Sajnos valami elszállt benne, valószínűleg egyik ic stb.
Aki tud segítsen.
Köszönöm
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Üdv minden kedves fórumtársnak!
Adott egy Kenwood KRF-V4080D készülék. A kérdésem az lenne, hogy valamilyen módon nem-e állitható benne a hangszin távirányitó nélkül? Sajnos elkallódott a távvezérlője, és a kézikönyv leirása szerint (Csak távvezérlővel) lehet a hangszint állitgatni. Valami tipp esetleg ötletet tudtok adni mit tudnék tenni? Csak mert nem tűnik egy rossz szerkezetnek.
Hello, I am in a repair KENWOOD KRF-X9995D.
Let me know if anyone is aware of how to reset the processor.
That is about a year ago I had the same problem with another amp of the same model!
So this is the second unit can not repair!
The main flaw is that the accumulation of around 1F 5.5V had spilled acid. was also in the same thing happened! ie it shows mute, but going into test mode, (having pressed the key "INPUT SELECTOR DOWN" and "POWER", the analog input works (but only in TEST).
Any help?
Thank you
