KLIPSCH K HORN SPEAKER SYSTEM SM
1.5 MB
Looking for similar klipsch manual?
KLIPSCH K HORN SPEAKER SYSTEM SM service manual (1st page)
Preview of KLIPSCH K HORN SPEAKER SYSTEM SM [1st page]
KLIPSCH K HORN SPEAKER SYSTEM SM service manual (2nd page)
Preview of KLIPSCH K HORN SPEAKER SYSTEM SM [2nd page]
    KLIPSCH HORN SPEAKER SYSTEM
Klipsch ProMedia 2.1 Amplified speakers
Original problem is no sub woofer output. Been through this one and recapped it and the common 2 burned 1K (R16/17)
resistors are replaced but the sub is still not responding. Volume control potentiometer is a common issue on these but
the L-R spkrs sound good.
Went by this webpage on the repair:
https://christopherbradshaw.net/The_Project_Bin/klipsch%20promedia%20subwoofer%20repair%20-%20page%201.html
On the schematic there is a sub-relay (sw101) powered by +V_HF line it
maybe is suppose to be +V_LF ? Without the relay coming on looks like the sub is disconnected.
The zeners (D03/04) that give +/- Vcc to the op amps seemed way off so I replaced them and the voltages seem much closer.
Theres also a sub-mute line on p104 to p101. Power supply shows the LF mute relay and interconnect diagram says it
gets fed from the LF amp. What is triggering the mute? I dont see a mute button anyplace.
Klipsch wifis soundbar parosítása más subwooferhez
Adott egy Klipsch soundbar,wireless módon kapcsolódik össze a subbal,ami sajnos tönkre ment.A kérdésem hogy esetleg csatlakoztatható -e másfajta mondjuk egy Samsung wireless subwooferhez ? Sajnálnam csak úgy kidobni vagy pl padlásra száműzni.
