Vásároltam egy ALTO gyártmányú DIGAN 2.14-es digitális equaliser-t. Működik rendesen, de bizonyos funkciók, csak a windows-os vezérlő programmal érhetőek el. A leírásban az ALTO honlapján letölthető programot írja. De valószínű, hogy eltávolították. Amit sikerült kiderítenem, hogy DiganEditor100.exe kell a működéséhez, az USB-s kommunikáció működéshez pedig PL-2303 Driver Installer.exe szükséges. A google sajnos nem talált semmit. Ebben kérném a segítségeteket.
Zsolt
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Sziasztok. A címben szereplő készüléket javítom és elakadtam. A tuner nem szól sztereoban és automata keresés esetén nem találl csatornát csak keres egyfolytában. Ha manuálisan beállítok egy csatornát akkor az szól de csak monóban. Nem vált át sztereora. Az IC1 LA1851 cseréltem de semmi változás. A kissebb kapacitású elkokat is cseréltem de semmi. Táp ic-t is cseréltem. Mi lehet a hiba? Rajzot sajnos nem találtam hozzá. A segítséget előre is köszönöm.
Sziasztok! Érdekes hibát tapasztalok az erősítőnél, a tulaj azért hozta el, mert nagyon sistereg a készülék a hangfalakon keresztül. Tényleg erős, fehérzaj szerű hangot ad a készülék, viszont amint leveszem 0-ra a hangszín beállításokat, akkor a zaj eltűnik, normálisan szól. Akkor, ha a magas, vagy a mély hangszínt a nulláról elállítom +, vagy - irányba, egyből bejön az erős zaj. Hangos zenénél ez nem feltűnő, de a csendesebb részeknél nagyon zavaró. Mindegy, hogy hány fokozatot állítok a hangszínen, nullától eltérő értéken egyből zajos. A power kapcsoló hosszú megnyomásával reseteltem, de nem változott semmi sem. Ez program hiba lehet, vagy a hangproci hiba okozhatja?
