LG CHASSIS ML-027 ML027 RP23LZ40 LCDTV ML 027 RP 23 LZ 40
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Hi everybody, my first post here.
I've found on this site many information and the service manual about the TV in subject, but I stumbled upon a strange issue.
I repaired the earphone socket (pic attached) that had been stripped away and now the TV doesn't power on, it only gives a short beep when you touch the power on button and nothing happens using the remote. I checked the usual things (audio paths, cracked solderings, damaged tracks, power supply, power rails), but I cannot found what's wrong.
Any idea/clue on what to (double) check this time?
LG 47LE5310 (LD01D) bekapcsolható, de csak az LG logó jön be, amely ciklikusan egy pillanatra a fejetetejére fordul.
Javítható ez az alaplap, vagy van esetleg valakinek ebbe való alaplap?
EBU60803661, EBU60803660, EBU60902211, EBT60927321
Szervusztok!
Van egy olyan problémám hogy az LG42PC3RA plazma tv-m kikapcsol.
Ha pihentetem, (teljesen áramtalanítva) azután újra működik.
Jelenleg bemelegszik, ezután kikapcsol és állandóan próbál újraindulni.
Sajnos Plazma ügyben nemigen vagyok jártas.
Tápot átmértem, elvileg a Standbye 5V is rendben van...
Ami számomra gyanús, hogy a Táp panel J729 Csatlakozó 3.3V-ON ágon 5V-ot mérek.
Táp panel: PKG1 PSC10166F M
Ha valaki esetleg tud ebben segíteni, azt örömmel veszem :)
Üdv.Mindenkinek,
A fenti készüléket hozta egy ismerősöm ma. ( LB 31/ LB36 chassis, LGP42-13PL1 táp )
Mivel holnap elutazunk próbáltam gyorsan túllendülni rajta, de a fenti jelenségen kívül nem találtam még más hibát.
A LED megható fesz. 100 és 125V között lassan ingadozik (157,5V helyett).
Az kondik jónak látszanak (mérve is)a táp többi része kifogástalan.
Szervízkönyvet találtam róla de abban pont a tápról nincs bővebb leírás.
Van valakinek ezzel a készülékkel már ilyen tapasztalata?
Esetleg a tápról bővebb leírása?
Csatolok néhány képet a könnyebb beazonosításhoz.
Minden segítséget előre is köszönök.
Tibor
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
