LG WF-32A-10S CHASSIS MC-52A IC CXP-85340 WF32A10S MC52A CXP85340 WF 32 10 MC 52 CXP 85 4064 SD 85340 32A10S 52A MODE WF-32A10S
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Aranyos drága kollégák, segítséget kérek, -keresek!
Szétszedve áll a fenti TV, jó Eeprom (24C512) tartalom kellene bele, ha jó a diagnózis. Néhány másodperccel a bekapcsolás után újra indul és ezt ismétli vég nélkül.
Minden sgítséget, tanácsot örömmel fogadok és előre is köszönöm.
Hi everybody, my first post here.
I've found on this site many information and the service manual about the TV in subject, but I stumbled upon a strange issue.
I repaired the earphone socket (pic attached) that had been stripped away and now the TV doesn't power on, it only gives a short beep when you touch the power on button and nothing happens using the remote. I checked the usual things (audio paths, cracked solderings, damaged tracks, power supply, power rails), but I cannot found what's wrong.
Any idea/clue on what to (double) check this time?
Udv tanyalakok!Fentemlitett keszuleket hoztak hozzam.Q423 2sc5858 pukk,c423 390p pukk de hianyzott is mert "valaki"mar korulszimatolta a gepet.Csere utan tv indult de sormeret kisebb volt,ugyanis a c424 9,5nf 1600v csak 3,5nf koruli ertekre volt mar csak kepes.Csere utan keszulek szepen mukszik azzal a "kis"szepseghibaval hogy kulombozo idokozonkent leall st.by-ba.Sor vegfok nem melegszik tul,kornyeken tobbi kondi kimerve,csokonyos allata megis tartja a magaet.Ha valaki tapasztalt hasonlot vagy tippje van megkoszonnem ha tudatna velem.
Tisztelettel:Feri
Kedves fórumozók!
Sajnos elakadtam egy LG 50PC55 plazma televízió javítása közben és a témában nagyobb tapasztalattal rendelkező fórumtársak segítségét szeretném kérni.
Az említett készülék először csak nehezen kapcsolódott ki, a bekapcsoló gombbal stand-by üzemmódba téve néha magától visszakapcsolódott. Pár hete viszont már nem lehet bekapcsolni. Pár másodperccel a bekapcsolás után kis ciripelés hallatszik, a relé kattan és a készenléti LED 7 zöld villogás után újra pirosra (stand-by) vált. Gondolom a táp-panel letilt, mivel valamelyik vezérlőpanelen rossz kontrol-feszültséget érzékel. Szétszedtem a készüléket (IMG_4370_resize.jpg) és átnéztem púposodó kondik vagy rövidre zárt alkatrészek után kutatva (IMG_4372_resize.jpg), de sajnos nem volt szerencsém. Az előírt feszültségek a táp-panel minden csatlakozójának minden lábán rendben voltak, az AC_DET lábon mért érték sem esett le bekapcsoláskor, tartotta az 5V-ot. Mivel a ciripelés az Y-SUS panelről jött, azt leválasztottam (IMG_4374_resize.jpg) és így a készülék bekapcsolt, de persze a képernyőn csak foltok jelentek meg. Miután visszakötöttem a panelt megmértem a feszültségeket ezen a panelon is és azt találtam, hogy a Z0_SUS_UP nem ugrik fel 0-ról 5 V-ra, mint ahogyan azt a párja, a Z0_SUS_DN teszi (IMG_4403_resize.jpg). Kiforrasztgattam a kondikat, megmértem őket. Ellenőriztem a diódákat és az ellenállásokat is, mind rendben volt. A felső hűtőborda alatt 4 db RJH3047-es IGBT tranyó és 2 db GF2030FC van (IMG_4404_resize.jpg). Nem kis nehézségek árán kioperáltam a bordát (IMG_4405_resize.jpg) és azt találtam, hogy a 4 tranyóból 3 nem működött. Beszereztem hát az új alkatrészeket (IMG_4408_resize.jpg) és összeraktam a panelt. Sajnos a bekapcsolás után csak az változott, hogy az eddigi ciripelés helyett élesebb hangot ad ki a Z-SUS, mielőtt letilt a táp-panel. A hanghatás talán ismerős lehet a tapasztaltabbaknak ezért készítettem egy rövid videót róla: http://videa.hu/videok/tudomany-technika/lg-50pc55-zb-stays-in-board-gf2030fc-igbt-K2Qv1L9apH4OXLFX
Szívesen venném, ha ötleteket adnátok, hogyan haladhatnék tovább a hibakutatással.
Köszönettel,
Laci
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
