Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Because I did not found it and I was forced to buy, you get it for free!
https://mega.nz/#!RlpCxCRQ!zhVCwJnC3dDiYlJSmDqRMOVeLzL7soairMfFxsup61A
Sziasztok ! A fent emlitett hifi a következőt produkálja: a hálozatra csatlakozáskor a hangfalak égtelen hangon búgnak,nem lehet bekapcsolni.Kicseréltem a 2 db tápkondit (3300uf,63v),majd cseréltem egy stk 4182II tipusu végfokot. Úgy nézett ki minden oké,most viszont a trafó 220v felöli biztijét nyomja el ha csatlakoztatom a hálózatra,várom az ötleteket,előre is köszi.
Sziasztok. A cimben szereplo erositovel szenvedek (szo szerint), mar egy ideje. Eloeleterol nem sokat tudni, hozzam eletjel nelkul kerult. Kibontas utan: szakadt biztositekok a sec. oldalon, a vegtranzisztorok ahany - annyifele/fajta, csillamlemezzel ugyan, de szigetelogyuru nelkul. Mas hibat nem talaltam, es a szigetelogyuruk hianyaban normalisak a szakadt biztositekok. A biztositekok es szigetelogyuruk potlasa utan az erosito megszolalt es megnyugodtam, hogy a vezerlo ic-k (upc1270h) megmaradtak. De ezekkel a vegtranzisztorokkal nem maradhatott, ujdonsult tulaja egy vajtfulu zenesz, meg az en reszemrol is kontarmunka lett volna bd242/243 parosokat bennt hagyni. Inkabb valami japan tranzisztorokat probaltam felhajtani, nem sok sikerrel, to220 tokozasban nem talaltam parokat. Vegul a fiokban lapulo 2sa1941/2sc5198 parokat tettem bele, kicsit izmosak ide, de ugy gondoltam csak nem fog kohogni ettol az erosito. Es itt kezdodik ez en kalvariam. A s.m.-ban az emiterellenallasokon mert feszultsegesest 3mV-ra kell beallitani. 0.003V/2x0.22R = 0.0068A. 6.8mA. Hat ez nekem marhara kevesnek tunt, igy sikerult nagyjabol a duplajara beallitani. Egyik oldalon siman ment, masik oldalon eleg messze kellett tekernem a trimmert amig meglett a 6mV. Szolni szolt, csak a vezerlo ic-k nagyon hamar felforrosodtak, igy gyartottam rajuk egy-egy szep nagy extra hutest. A gyari hutozaszlok nagyjabol a fele az ic-k adatlapjaban megadottnak, nem is ertem hogyan mukodott ez az erosito gyarilag. A kovetkezo huzas az volt, hogy amig fulhallgatoval szepen szol, mihelyst rakotom a muterhelest, az egyik csatorna kezd torzitani. Idonkent helyrejon egy-egy kis idore, mintha kontakthiba lenne, de hiaba kocogtattam vegig a panelt, nem volt valtozas. A vegerosito panelt atforrasztottam, aztan ugyanez a 2 elulso panellal is, de a hiba maradt. Ha rakotom a muterhelest, egyik csatorna torzit, ha lekotom, a hang kitisztul. Legutoljara azon a csatornan, ahol nehezebb volt a nyugalmi aramot beallitani, vegtranzisztorokat csereltem es beallitottam a kivant 3mV-ot. Ennek ellenere nem tapasztalok kulobseget a 2 vezerlo ic homersekleteben, ugyanugy melegszik mindketto. Elore is koszonom, ha valakinek sikerulne felkapcsolnia az alagut vegen a fenyt. Udv.
