Szevasztok!
Egy ismerősöm keresett meg, hogy a mellékelt töltőnek az elektronikája
szénné égett, de valahonnan szereztek egy vadi új panelt bele, de nem jegyezték
fel, hogy az 5 sarut honnan húzták le.............én se tudom! :)
Ebben kérek segítséget, mert nem akarom tönkretetetni az új panelt.(bizonyára van aki csípőből tudja)
A trafónak 3 szekunder kivezetése van, és a még 2 saru a + - csipesszel.
köszönöm
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Kollégám hozta ezt a masinát. Felpumpálja a mandzsettát, majd ahogy kikapcsol a pumpa, le is enged. A mágnesszelep 6 voltos, indításnál megvan a 6 volt, majd mikor leáll a pumpa, az is leáll. Ha jó gondolom, a mágnesszelepnek akkor kellene csak nyitnia, ha befejezte a mérést. Esetleg vmi ötlet? Köszi!
Adott egy ilyen:
Gyerek konzol gyűjtési mániájának egy újabb darabja.. Nem olvas lemezt. Ok, mi lehet, mi lehet :D Laser csere. Ali, KSM-440BAM laser van benne. Vettem egyet, 7e Ft. Az egész vacak nem ér ennyit, de legyen.. Bele tettem, indul, nyuszetöl, teker, kerreg, de nem olvas... Hmmmm... Vissza a régi, azzal meg sem mozdul.. Teljesen új volt, lehegesztett fekete műanyag antisztatikus céldobozban, eladó adott el vagy 50 darabot, 4,7 értékeléssel...
Hmmm... olvasom az értékeléseket, be kellett állítani többnél is a potival.. Na itt nekem már szól a vészcsengő, mert azért egy új legyen már beállítva...De legyen.. kb 1 óra szenvedéssel néha olvas gyári lemezt.. néha..
Eladó kér videót.. De minden kifogás, nem tudja megnyitni, nem jó a jutyub link, nem jó a file megosztó, vagy a gugli drive.. mailt nem kapja meg...
Szóval vegyek megint egyet?
Van valakinek rendes kalibrációs leírása ehhez a verzióhoz? Nem, nem az, hogy tekergessem, míg jó nem lesz :)
vagy más hiba, ami tud ilyet? Tele van azzal a katasztrófális minőségű alu smd kondikkal, ami a sonyra jellemző volt akkor, de nem érzem a késztetést, hogy brahira újrakondizzam :)
Rég volt, de biztos javítottak sokan ilyet, remélem innen is :)
