Tudna valaki segíteni abban, hogy mi lehet a tipusa ennek az autórádiónak, hogy próbáljak rajzot keresni hozzá?
A D2003-as IC van felrobbanva... Semmi felirat rajta. Persze, ha tudja valaki, az még jobb volna...
Köszönettel:
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Egyik régi ismerősöm keresett meg ezzel a rádióval, csak a bekapcsolás, hangerő és cd kiadás működik. A többi gomb néma.
Sok topik foglalkozott már ezzel, inkább honda jazz típussal. Ugyanaz a rádió.
https://elektrotanya.com/content/honda-jazz-autoradio-megoldva
Többnyire egy ba08cc0wfp-e2 stabilizátor szokott megszakadni, ugyanezt a hibát produkálja - elvileg. Illetve azt írják hogy ennél a stabilizátor hibánál a gomb hiba mellett a rádiónak hangja sincsen. Ez a stabilizátor 8V -ot állít elő, és kikapcsolható. Ami nálam van az 8.4V -ot csinál, és rendben ki-be kapcsol.
A javítandó készüléken van rendes fm zaj, és a cd rendesen szól. Csak léptetni nem lehet.
A működő gombok és az encoder közvetlenül van bekötve az alpalapi processzorba, ami nem működik gomb azok a kijelző vezérlő ic -be vannak kötve. Az összes gombot megmértem, mindegyik jó. A kijelzővezérlő ic ( LC75883 ) ad jelet a gombok egyik lábára és figyeli a másikat. A key-req lábon át csatlakozik az alaplapi processzorhoz, itt állandó jelsorozat van - még kikapcsolt (készenléti) állapotban is. Sajnos nem látom hogy változna a gombok nyomogatásától.
Viszont a gombok egyik felén van, a másikon nincs jel ha végigméregetem. Ez elvileg jó. Ha megnyomom a jel átmegy.
Mintha a kijelző vezérlő ic lenne rossz, de a kijelzőt tökéletesen működteti. Csak a gombokat nem.
Ami még tovább bonyolítja, hogy a jobboldali encoder is az alaplapi prociba megy közvetlenül, nem csak a hangerő encoder. De az sem csinál semmit, pedig mindkét lábán rendesen változik a feszültség 0 és 5V szintek váltakoznak. Rendesen, néhány fokkal eltolva egymástól.
Ami feszültség fel van írva az mind megvan.
Minden stabilizátorról jön le kimeneti feszültség.
Az össze elko -t kicseréltem próbára.
Mikor elromlott, egy pár nap múlva megjavult néhány napra, majd újra elromlott.
Minden gyanús forrasztást átforrasztottam. Már órákat méregettem és vizsgálgattam.
Régebben olvastam ennél a típusnál hogy elfárad egy processzorba épített flash memória, és nem szabályozható többé a hangerő. Na ennél fordítva van, csak a hangerő szabályozható jóformán semmi más.
