NEO CHASSIS 21CK-4
TV - EPROM
Type: (HEX)
1024.0byte
EPROM
Looking for similar neo manual?
    NEO CHASSIS 21CK4 21 CK 21CK 21CK-4
TV Neo 2159TX
Sziasztok Nem tudja valaki ,milyen taviranyito talal ehez atv-hez Koszi
neovia neo-2005dtx
Üdv mindenkinek! Tudna valaki segíteni, egy Neovia NEO-2005DTX-hez, vettem egy Medion MD83388 típusú univerzális távirányítót(az eredeti elveszett), de nem találom a megfelelő kódot. Köszönöm fblaci
LED TV NEO LED-2202FHD It does not work, the front LED off ,power supply is OK
Mark:NEO LED-2202FHD
Model:LED-2202FHD
Chassis (main board, components): 17MB60-3 flash 25Q80
LCD Screen/Panel :: LC215EUN (SC) (A1)
More informations:   Power supply 17PW05-2
   _SN : 6694377 100624
It does not work, the front LED off, the power supply is ok.It was software on usb several times, periodically every 2-3 months and it worked, finally it was left with the st.by LED off, that's why I-m thought about flash memory. Thanks a lot!
NEO TV-2132TX.
eeprom tv NEO TV-2132TX..procesor:TDA9352PS.N2.3I
