I want to upload this manual for anyone may need it. But it excess the limit files attached. Pls IB me if you want.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Van egy Onkyo TX-NR509 erősítő ami ugye a jellegzetes DSP hibával jött hozzám! DSP chip újra golyózva de még mindig nincs hang a HDMI oldalon!
A netet böngészve arra jutottam hogy a DSP chiphez tartozó firmware lehet a hibás ezt kéne újra írni...de sajnos ehhez nekem nincs technikám...
Valami miatt nem tudok USB ről sem frissiteni mert egyszerűen a menüben nem aktív az a menüpont ahol el lehetne végezni a frissítést ezt mondjuk nem értem miért nem engedni?
Valaki ebben tudna nekem segíteni?
CSatoltam három képet hogy mit ír ki ez erősítő ha megnézem rajta a firmware verziókat , ugye a DSP nél csak ?????? jelek vannak ami hiba...
Van pár onkyo-s hang problémás topik, de nem találtam ezt a típust. Onkyo tx sr 703 e.
A probléma, nincs hang. Minden funkció működik. Néha előjön, resetelést követően, olykor halk, stb.
Arra figyeltem fel, hogy az egyik hűtőborda nagyon fűt. 4 tranzisztor van rajta. Képet csatolom. Nem tudom ez mit csinál az erősítőben. A bekeretezett rész.
Ha valami tudna irányt mutatni, köszönöm!!!
