Sziasztok. A cimbeli erolkodovel kuzdok, a problema a kovetkezo: ha az FM mute aktiv (on), nem talal adot, ha kikapcsolom, az automata keresovel nem talal adot, de kezi keresessel bejonnek az adok, es memorizalni is lehet oket. Ha valaki erti hogyan mukodnek ezek a dolgok, kerem adjon nehany tanacsot. Koszonom.
kerüt hozzám egy onkyo tx-100-as erösitö és amikor bekapcsolom
a bal oldal szépen szól.
a jobb oldal 3-asig megse szólal onnantól feljebb halk recsegésbe kezd még feljebb tekerve hangosan recseg.
szerintetek végfokhibás?
végfokja egy STK459-es IC
az elöfok biztos jó fülhalgatóval teszteltem testhez képest elsönek az 1-es majd a 16-os lábhoz.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Adott egy Onkyo erősítő, melynek a hibája, hogy a kijelzője teljesen sötét, amikor bekapcsolom. Minden más működik rajta, hang is van. Csak a kijelzője nem. Kérem,aki tud az adjon tanácsot,hogy merre induljak el a hibakeresésben. Előre is köszönöm. Csatolok hozzá rajzokat.
