Hello!!
Ha valaki el tudná nekem küldeni az Onkyo Tx-7430 erősítő kapcsolási rajzát nagyon megköszönném :)
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Sziasztok! Onkyo TX-7520 manuáljára lenne szükségem ha valakinek megvan köszönöm.
javítok több féle onkyo erősítőt DSP hibával, (ha bárki is belevágna ez alapján tudnia kell a chip beszerzése nagyon nehéz, ebay aliexpress kilőve mint ahogy a reballozás is !!!) új dsp chippel és ha szükséges flash programozással, minden rendben ment az xx08 as modellektől felfelé, de most a kezembe akadt egy NR807 - es szokásos javítas felraktam az új chipet flash adat jó mert felbootol vele, de nincs hang...
Tmsd830k011azkb helyére épült d830k013dzkb5 ( eredeti )
kipróbáltam már 808-as flash adattal és másik 807-es flash adattal de semmi hang nincs... bekapcsolja a hangfalakat és vége, gondolom a 2nd dsp vel nem megfelelően kommunikál.
hogyan oldható ez meg ?
Chip kell rá más fajta, szoftwaresen, hardvesen kell ezt megoldani ?
mindenhol olvastam hogy az NR 807-essel másképp kell de nem találtam meg mi a pontos megoldás.
