Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Van egy Onkyo TX-NR509 erősítő. A hiba jelenség: bekapcsolásnál a Check SP Wire hibaüzenet jelenik meg, szinte egy pillanatig, majd utána kikapcsol. Kérnék egy kis segítséget a hiba behatárolásához.
Hello,
Trying to get a replacement part which is this ceramic cap.
Does anyone know the value (uF and voltage) of this cap?
Many thanks.
Ray
Sziasztok! A segítségeteket szeretném kérni a fent nevezett erősítővel kapcsolatban. Minden működik rajta, de nem jön ki belőle semmi hang. Az egyik ismerősöm hozta, hogy nézzem meg neki, ugyanis a felesége mindig letakarja a szellőző nyílását a tetején egy terítővel mondván biztosan leégett a végfoka. A végfokait megmértem mind jó. Mi lehet a baja? És nem igazán akar működni rajta a hangerő gomb sem (sokszori körbetekerés után 1-et változik) a távirányítóval tökéletesen működik.
