I want to upload this manual for anyone may need it. But it excess the limit files attached. Pls IB me if you want.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Van egy Onkyo TX-NR646 házimozi. Bekapcsolás után ezt az üzenetet írja ki. NG:LCRSLSRBLBR. A reset nem segít. A végtranzisztorok mérve jók, feszültségek megvannak.
Van valakinek ötlete, hogyan tovább?
Előre is köszönöm.
Mindenkinek Boldog Újévet Kívánok!
A fenti típusú ONKYO rádió-erősítőt javítom.
Eredetileg az egyik végfokozat rossz volt.
Cseréltem a következő alkatrészeket:
Q506 (2SC3421) és Q507 (2SA1358) meghajtó tranzisztorokat,
Q508 (2SC3855) és Q509 (2SA1294) végtranzisztorokat,
Q505 (2SC1815) nyugalmi áram beállító tranzisztort,
R510 (270 ohm) ellenállást valamint a két nagyáramú (2A) biztosítékot.
Megnéztem R507 (10 Kohm) potenciométert kontakthibára, de jónak találtam.
Elindítottam a végfokot és beállítottam a nyugalmi áramot.
Minden rendben volt, elindult hiba nélkül a készülék, járattam kis hangerőn pár wattal.
Már csak a fedlapját kellett volna rátennem amikor egy villanást láttam és elhallgatott.
Mérés alapján a javított végfokozat két végtranzisztora ment teljes rövidzárba valamint megszakadt a két nagyáramú (2A) biztosíték.
A jelenség okát nem tudom, van valami tippetek?
A végfokozat kapcsolási rajzát (TX-7430) mellékeltem.
Kumi
