Attached is the DSP2 Firmware for the Onkyo NR646.
Hi everyone
Could somebody tell me if I can replace a switching diode to another one, the one installed in the onkyo is a 1SS252 and is 10 times more expensive that a 1SS355.
Usually I order the same but they are pricey (around 10.00 usd for a 100) and not commonly used, not many sellers.
For the 1ss355 every seller on line has it in stock and it's around 1 to 2 usd for a 100.
Ans they are available locally, not in china waiting 5 weeks for the part.
Thank you.
1SS352
Characteristic Symbol Rating Unit
Maximum (peak) reverse voltage VRM 85 V
Reverse voltage VR 80 V
Maximum (peak) forward current IFM 200 mA
Average forward current IO 100 mA
Surge current (10ms) IFSM 1 A
Power dissipation P 200 (*) mW
Junction temperature Tj 125 °C
Storage temperature Tstg −55~125 °C
1SS355
Maximum (peak) reverse voltage VRM 90 V
Maximum (peak) forward current IFM 225 mA
Surge current (1s) IFSM 500 mA
Junction temperature Tj 150 °C
Storage temperature Tstg −55~150 °C
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Hozzám került egy Onkyo TX-SR500 erősítő, nem jön ki belőle hang. Bekapcsol, kezelőfunkciók működnek, de hangot sehogy nem ad. Oszciloszkóp nélkül nehéz...Tápok szerintem megvannak mindenütt. Valaki nem találkozott ilyen hibával? Gyanakszom a bemenet választó IC-re.
