Sziasztok. Hibasan vettem egy Onkyo Tx8410r tipusu radios erositot. A hangsugarzovedo relei voltak hibasak. A bajom most az, hogy a 2 savos hangszinszabalyzoja igencsak sovany tartomanyban fejti ki hatasat, jo esetben talan +- 2 dB-t erosit/vag. Ezt szeretnem elfogadhato mertekre tornazni fel, es ebben kerem a segitsegeteket merthogy en ehhez mar nem ertek. SM van fenn a Tanyan. Udv.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Üdv mindenkinek. Hozzájutottam egy Onkyo erősítőhöz, melynek a hibája, hogy egyrészt 120v-os hálózatra készült, hálózati csatlakozója hiányzott. A készenléti táp panelon kicseréltem a trafót 220v-os feszültségűre. A táp. trafót kikötöttem róla. Majd bedugva a hálózatra a készenléti táp reléje csak kattog mikor bekapcsolom. Kérdésem még, hogy esetleg melyik tipusú erősítő 220-as trafója lehet jó bele az onkyo-k közül? mert akkor kicserélném benne. Előre is köszönöm a hozzászólásokat.
Jó napot mindenkinek!
A típus A-8630. Letakarták és úgy üzemeltették.Kiverte a hálózati biztosítékot.A tulaj átkötötte,és eleinte elindult. Most már csak kiveri a biztosítékot.Ha lekötöm a hálózati trafó szekunder oldalát nem változik semmi.Ha a trafó egyik bemeneti ágát kikötöm nem olvad ki a biztosíték.Szerintem rossz a trafó,de már nem gyártják.Tud-e valaki valamilyen beszerzési forrást?
dínó
