I have a Onkyo DX-7333 CD player, which sometimes doesn't recognize CDs.
I don't think it's a laser pickup (KSS-213C) problem, because when it recognizes the CD, it plays it without a problem, even very scratched ones.
The next thing is, it should play CD-RWs, but it doesn't even recognize them.
I think it needs adjustment
There are two pots on the main PCB - Focus Gain R123 and Focus Offset R112.
Also there are two test points:
TP1 4 pins, first pair labelled Tracking Gain, second pair Focus Gain
TP2 2 pins labelled RF Out and VC
But in the service manual is no description, what should be measured on the test points and how to set Focus Gain and Focus Offset.
In the attachment is a cut out from the schematic, where the test points and adjustment pots are.
Please if someone knows, how to?
Hi everyone
Could somebody tell me if I can replace a switching diode to another one, the one installed in the onkyo is a 1SS252 and is 10 times more expensive that a 1SS355.
Usually I order the same but they are pricey (around 10.00 usd for a 100) and not commonly used, not many sellers.
For the 1ss355 every seller on line has it in stock and it's around 1 to 2 usd for a 100.
Ans they are available locally, not in china waiting 5 weeks for the part.
Thank you.
1SS352
Characteristic Symbol Rating Unit
Maximum (peak) reverse voltage VRM 85 V
Reverse voltage VR 80 V
Maximum (peak) forward current IFM 200 mA
Average forward current IO 100 mA
Surge current (10ms) IFSM 1 A
Power dissipation P 200 (*) mW
Junction temperature Tj 125 °C
Storage temperature Tstg −55~125 °C
1SS355
Maximum (peak) reverse voltage VRM 90 V
Maximum (peak) forward current IFM 225 mA
Surge current (1s) IFSM 500 mA
Junction temperature Tj 150 °C
Storage temperature Tstg −55~150 °C
Üdvözlet Mindenkinek!
A fent jelzett készülék azzal a hibával került hozzám, hogy minden része tökéletesen működni látszik, csak éppen hangot nem ad ki, tökéletesen néma.
Az erősítő minden utasítást kijelez, bekapcsolás után kb. 5 másodperccel kapcsolnak a hangszóró relék, de minden kimenete néma marad. A tápfeszültségek rendben vannak, a védő áramkör beszabályozását a szervíz utasítás szerint elvégeztem. A "Test Mode" nem működik, az SM-ben üzemzavar esetére javasolt eljárásnál / VIDEO1 és HANGSZÓRÓ A egyidejű lenyomása/ megjelenik a "CLEAR" a kijelzőn, de stby-ba kapcsol a készülék, és semmi változás, a hiba marad. Kérem a témában és a fenti típusú erősítő szervizelésében jártas kollégák segítségét a lehetséges hibák behatárolásában.
Sziasztok Kollégák !A fenti készülék bekapcsolás után 3 mp. múlva kikapcsol a ko felső sarokban egy ASb felirat van.
A 3 mp.alatt amíg él a kijelző minden funkciót lehet kapcsolni,hangerőt állítani,bár nem szólal meg, de sajnos kikapcsolás után sötét kijelző van.
Az AUTO STANDBY feliratnak lehet ehhez köze, vagy valami mástól kapcsol ki ?
Rutinból a végfok tranyókat néztem meg, de minden rendben van, a meghajtó panelon sem találtam semmit,kihúztam , úgy is ez a jelenség áll fenn.
Mi a véleményetek, volt már Valakinek ilyen esete ?
Előre is Köszönöm segítő véleményeteket !
Üdv :service
