Hi everyone
Could somebody tell me if I can replace a switching diode to another one, the one installed in the onkyo is a 1SS252 and is 10 times more expensive that a 1SS355.
Usually I order the same but they are pricey (around 10.00 usd for a 100) and not commonly used, not many sellers.
For the 1ss355 every seller on line has it in stock and it's around 1 to 2 usd for a 100.
Ans they are available locally, not in china waiting 5 weeks for the part.
Thank you.
1SS352
Characteristic Symbol Rating Unit
Maximum (peak) reverse voltage VRM 85 V
Reverse voltage VR 80 V
Maximum (peak) forward current IFM 200 mA
Average forward current IO 100 mA
Surge current (10ms) IFSM 1 A
Power dissipation P 200 (*) mW
Junction temperature Tj 125 °C
Storage temperature Tstg −55~125 °C
1SS355
Maximum (peak) reverse voltage VRM 90 V
Maximum (peak) forward current IFM 225 mA
Surge current (1s) IFSM 500 mA
Junction temperature Tj 150 °C
Storage temperature Tstg −55~150 °C
Hello,
Trying to get a replacement part which is this ceramic cap.
Does anyone know the value (uF and voltage) of this cap?
Many thanks.
Ray
Fent nevezett végfoghoz keresek kapcsrajzot,eddig eredménytelenül,vagy útmutatást,hogy merre induljak,mit mérjek?
Ha tudna valaki segiteni,nagyon megköszönném.
Üdv! György1960
email:gyorgy1960@citromail.hu
ha lehet akkor ide kérném,mert a régi telefonom még ennyire képes,amikor uton vagyok.
Sziasztok. A cimbeli erolkodovel kuzdok, a problema a kovetkezo: ha az FM mute aktiv (on), nem talal adot, ha kikapcsolom, az automata keresovel nem talal adot, de kezi keresessel bejonnek az adok, es memorizalni is lehet oket. Ha valaki erti hogyan mukodnek ezek a dolgok, kerem adjon nehany tanacsot. Koszonom.
