Üdv!Kaptam egy nagyon leharcolt erősítőt,nem tudom megéri-e vele foglalkozni mert a távirányítója sincs meg, de a végfoka az én stk-mhoz képest komolynak néz ki.
Keresnék olyan vállalkozó kedvű szakembert aki esetleg elvállalná a javítást, én ugyanis autószerelő vagyok,szerintem nekem túl nagy falat lenne.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
I want to upload this manual for anyone may need it. But it excess the limit files attached. Pls IB me if you want.
Kedves kollégák!
Tanulságos hiba megoldását szeretném közzétenni, ha valaki találkozik eme jelenséggel, / könnyen lehet, hogy típushiba/ egyszerűbb lehet a megoldás. A hibajelenség: Minden működött a gépen csak éppen egy hang nem jött ki a kimeneten. Táp, végfok minden jó volt, a hűtő ventilátor nem ment. Gyanús volt, hogy valami tiltás az oka a jelenségnek. A Main circuit PC board nevű, "U1" jelű panelen található memória kapacitás nyák felőli oldalán egy pici rozsdafolt jelezte, hogy kilyukadt. A kigőzölgő elektrolit a lyukgalvanizálást szétmarta több ponton. A pontok vezetékkel való pótlása és a kondi csere után a hiba elhárult. Laszlo 61 :D
