Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Hello,
Trying to get a replacement part which is this ceramic cap.
Does anyone know the value (uF and voltage) of this cap?
Many thanks.
Ray
A feleségem kollégájától kaptunk amolyan kukaszökevény jelleggel egy Onkyo mini hifit, aminek része ez a deck is. Mivel kívülről szép állapotú ezért gondoltam megjavítom.
Full auto reverse mechanika van benne egyetlen motorról hajtva. Az első próbánál azt tapasztaltam, hogy kattog (próbálkozik) de valójában nem csinál semmit a kazettával. Szétszedve azt tapasztaltam, hogy a főszíj le van esve, megörültem, hogy na ennyi az egész, de közben az is bennem volt, hogy csak úgy magától nem esik le az a szíj... persze nem is lett jó. Most ott tartok, hogy a mechanika látszólag nyugalmi helyzetben van, de a főtengely (ami jelen állapotban épp kontaktusban is van a program tárcsával) néhány fordulat után befeszül. Van a vezérlő szolenoid, ez is látszólag működik, behúz (ez kattogott a.próbáknál) viszont hiába húz be a főtengely ugyanúgy befeszül.
A manuálban van egy robbantott ábra, de nem túl részletes (pl. Mi a program tárcsa nyugalmi helyzete) hogy érdemes nekiállni?
Szervusztok Mesterek,
Keresem az Onkyo TA2640 kazettás magnó szervízkönyvét, ha valaki feltöltené, vagy elküldené privátban, megköszönném.
üdvözlettel
Fand895
