Kedves kollégák!
Én még ilyen gagyi hibával nem találkoztam. Ha bedugom a lan kábelt a TV rögtön lefagy,majd kikapcsol és ujra indul ismét lefagy. Egyébként e nélkül tökéletesen üzemel. Az RJ45 aljzatot már kicseréltem. Zárlatot nem mérek a kimeneten. Nincs valakinek egy spi mentése vagy USB s firmware. Esetleg valami tapasztalat.
main: 17MB100
cimke:10096357 232648824 88 40" 27391643 DIJ
LCD: VES400QNSS-3D-U01
PSU:17IPS20 071114 R9
üdv.
Manufacturer: Panasonic
Type: TX-L42ETW5
Chassi: LA35
Hello everybody,
I could determine or measure the following with the device:
Device does not start anymore, stand-by LED lights red when device is plugged in and flashes red as soon as an IR command (key press) is sent via the remote control. Voltages of power supply STB 5V and signal LCD_TV_SUB_ON come from A-board. Power supply starts, supplies P15V and SUB1.1V, 1.5V, 1.8V, 3.3V, 5V, HDMI3.3V and USB5V are generated on the A-Board (stand for about 2.5 seconds). Then signal LCD_TV_SUB_ON goes low (voltages go away to STB 5V) and after about 2 seconds back to high (endless). What is missing is the voltage PNL12V which is switched on by PANEL_VCC_ON2. PANEL_VCC_ON2 always has a low signal and does not change its state. Power supply also provides for the 2.5 seconds the 24V for the backlight. Clocking of LCD_TV_SUB_ON starts immediately after plugging in the mains plug (also without IR command). SOS error code is not output. The over-voltage circuit in IC 5000 pin 7 also does not respond. Attached is the timing diagram from the technical training of Panasonic where I have drawn until when the boot process behaves normally.
In my opinion a mistake on the A-board? Does anyone have a tip?
greetings
Andi
Üdv Mesterek!
Még nincs nálam a gép.
Rajzot töltöttem már le erről a sasszéról ( igaz az a típus TX-P42G20 de a sasszé ua. ) , de abban csak 12-ig van hibakód, ez meg 13-t villog.
Hátha valaki tudja....
sziasztok
keresek Panasonic TX32PS12P tv-hez sorkimenő trafót
száma : CO3705106870
13022002CB08
ha valakinek lenne át venném
további szép napot
