Kérem, guriga és Guest ne szóljon a topichoz!
Tudnátok segíteni?
Lenne ez a gép. Random módon elmegy a kép, visszajön, elmegy stb. majd
kikapcsol, és 8-at villog a stby led. Csak áramtalanítás után
kapcsolható vissza .
Ez a fajta SS van benne. A csatiakat átnéztem, a földelő csavarokat megtéptem.
Ezeket végigcsináltam amit ír a 8 hibára.
www.werbemousepads.de/pdf/2012_Plasma_TV_Troubleshooting_Guide_2012_04_16_revised.pdf
Van valakinek más ötlete esetleg?
Kösz
Anyone ever do one of these to a CRT?
Seems like the set has this jungle IC which will be where the RGB lines
for the OSD are needed for the mod:
https://pdf1.alldatasheet.com/datasheet-pdf/view/13342/PANASONIC/AN5304NK.html
Am not sure what the line would be that tells the chip to turn the OSD on. Apparently there
is a line if its 1 volt or more, it activates the OSD, if zero its normal video.
Also I think there must be a sync line tapped into which is bought out to the rear of the set,
with the (3) RGB lines / jacks but not sure where that would be tapped into?
I am gonna use BNC jacks, not the scart connector.
There are some youtube videos about RGB modding and lots of topics on the shumps
forums but so far it seems no one has tried this with Panasonic.
Steve Hearns
Technotronic Dimensions, VT [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Hello,
I have a Panasonic TX-68PS20A 68cm (29") Television with a GP3 chassis. (Australian PAL model)
The documentation I have found online says that the gp3 chassis supports VHF PAL-B/G and NTSC-M. However my tv doesnt support M audio. It just tunes the video and gives white noise through the audio since it's looking for B audio even though it's displaying ntsc video just fine.
I have found no options for this in any of the service menus I've accessed. Am I missing something?
I don't mind if I have to reflash something to make this work.
Here is the pdf which I read the specs from, it's not for this model but a similar one with a gp3 chassis. http://elektrotanya.com/cgi-bin/download2.cgi?uid=37145&cid=1417425157&fid=117149&file=panasonic_tx-29psxx_gp-3.pdf&x=26&y=30
Üdvözlet mindenkinek. A cimbe emlitett Z7 es sasszival szerelt tv t ,szeretném megmenteni ,sajnos trafo hibás ,a trafo tipusa ZTFK33005A a megfelelője HR8327 lenne ,de nem találtam .Megprobáltam bekötni egy BSC25 5515 öt, ezzel el is indul egy pár másodpercre ,aztán belép a védelem . A vertikális fokozat táplálása + - 14 V ,a video fokozat tápja 176V . külső táprol betápláltam a fütést és azalatt a rövid idő alatt megjelenik a fény is. Az lenne a kérdésem hogy hogy lehetne kiiktatni a védelmet ideiglenesen ?
