megakadtam egy ilyen készülékkel. A hiba: kép nincs, háttérvilágítás megy, műsorhang van. Kékesszürke homogén fény dereng a kijelzőn, OSD sincs. Tápok megvannak. Tartok tőle hogy nem fogok megbirkózni vele.
Véleményetek szerint merre induljak a hibakeresésben?
A rajzot letöltöttem és az alapján alaposabban végig fogom mérni a tápokat, de attól tartok hogy ez kevés lesz.
Köszi előre is.
Tamás
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Adott a tárgyban jelzett, ES1.E alaplapos sík csoda.
Készenlét van, valamit hallani de letilt majd villog.
2-szer lassan villan, majd 7-szer gyorsan.
27-es hibakód létezik ezeknél vagy mi ez?
Illetőleg igazából a cső kéne máshova, a kérdés itt az is főként, megéri eme Philipsel bajlódni, vagy jobban járok ha a másik képcsőbajos gépbe átteszem ebből a jó csövet?
Pityesz
Mester urak!
A fenti tv-hez szeretnék segítséget kérni. A kép nagyon sok idő mulva jön be.10-15 perc is lehet. Amíg nincs kép a TDA 6101Q nem ad vissza jelet a TDA 4780-nak. A 6101-eken a 12 és 200 V megvan, a többi akkor áll be rendes értékekre amikor elkezd működni. Ha egy pillanatra kikapcsolom akkor is sokára jön be a kép, de kikapcsolásig megmarad. Ha bejön a kép a fehér egyensúly se teljesen ok. A kék egy kicsit gyenge. A képcső elfáradása az oka a késői felállásnak? Ha igen akkor nem lehet valamivel elősegíteni a beindulást? Már ugye képcsőcsere nélkül. A képcső típusa W66ESF 002x44.Azt hallottam, hogy ezeket a Philips csöveket nem sok sikerrel lehet regenerálni.
Előre is kösz.: kollerp
