Ennek a videos tvnek hogy lehet belépni a hangolássába, mert a menü gombnál nem ad fel ilyet, vagy hotel modban lehet, ezt hogy lehet kivenni belőle, vagy epromot kell újra írni? Segítségeteket előre is köszi
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Tisztelt Fórumtársak!
A címben szereplő TV készülék javításában elakadtam és szeretném a segítségeteket kérni.
Hozzámkerülését követően az alábbi hibajelenséget produkálta:
- A készülék a feszültség alá helyezés után a LCD panel háttérvilágítása elindult, megjelenik a PHILIPS logó rövid időre majd az egész folyamatot újrakezdi.
A javítást a tápegység átnézésével kezdtem. A szekunder oldali elektrolit kondenzátorok rosszak voltak (szokásos kiszáradás, felpuffadás). Az összeset cseréltem az eredetiekkel megegyező 470uF/25 voltos low-ESR típusra. A primer oldalon két 47uF/450v-s kondenzátor közül az egyik kapacitása kicsi volt és a kettő helyett tettem egy darab 100uF/450V-s elektrolit kondenzátort. Ez utóbbi némi eltérés az eredeti állapothoz képest de gondolom nem változtat a lényegen. A cseréket követően a tápegység jó, valamennyi feszültség stabil (12V) és a inverter oldalon a 20V-s feszültséget mérek. Az is stabil.
A probléma az, hogy a hiba amivel hozzámkerült ugyanaz. A készülék nem indul el, boot folyamat megy körbe-körbe.... Próbáltam lehúzni a háttérvilágítás LED csatlakozót hátha az terheli meg a tápegységet de a helyzet ugyanaz marad!
A készülék az alábbi alaplappal van szerelve:
Hálásan köszönök előre is minden segítséget!
Nekiestem egy 22"-os Vestel-Philipsnek LCD TV-nek, halott a háttere.
A kijelző TC236BJ11, az egyik éléről világít. A 35db (5x7-es csoportban) 7020-as led jelentős része dög, de nem ez a legnagyobb baj. A 16. led alatt sérült az alu hordozó, ezért abban a szegmensben két led söntölődik, ezáltal csak 5 led világít a 7-ből, így a többi szegmens a leeső feszültség miatt sötét.
Tehát keresnék ilyen led bart (TC236F101-I07050-LA1), akár bontásból is.
Így néz ki:
https://www.tveczanesi.com/led-back-light-strip-tc236f101-i07050-la1-screen-tc236bj11-for-polaroid-p24led13.html
