A tévé nem ad hangot. Egyik bemenetről sem. Letöltöttem a szervizkönyvet, és
" Service Modes, Error Codes, and Fault FindingEN 12 TCM2.0E LA5.
5. Service Modes, Error Codes, and Fault Finding
Index of this chapter:
5.1 Test Points
5.2 Service Modes
5.3 Error Codes
5.5 Service Tools
5.1 Test Points
This chassis is NOT equipped with test points in the service
printing. No test points are mentioned in the service manual.
5.2 Service Modes
The Service Mode feature is split into different parts:
• Service Alignment Mode (SAM).
• Service Default Mode (SDM).
• Customer Service Mode (CSM).
SDM and SAM offer features, which can be used by the Service
engineer to repair/align a TV set. Some features are:
• Activates the blinking LED procedure for error identification
when no picture is available (SDM).
• Make alignments (e.g. white tone), (de)select options,
enter options codes, reset the error buffer (SAM).
• Display information (“SAM” indication in upper right corner
of screen, error buffer, software version, options and option
codes, sub menus).
The CSM is a Service Mode that can be enabled by the
consumer. The CSM displays diagnosis information, which the
customer can forward to the dealer or call centre. In CSM
mode, “CSM”, is displayed in the top right corner of the screen.
The information provided in CSM and the purpose of CSM is to:
• Increase the home repair hit rate.
• Decrease the number of nuisance calls.
• Solved customers' problem without home visit.
5.2.1 Service Alignment Mode (SAM)
How to Enter
To enter SAM, use the following method:
• Press on the remote control the code “062596” directly
followed by the “INFO” key.
After entering SAM, the following screen is visible, the values
can be adjusted according to the requested (see Chapter 8"
Szóval a saját távirányítóján az INFO gomb helyén időzítő óra jele látható. Ha beütöm a 062596 kódot, az első két szám után jön az üzenet, hogy nincs ilyen csatorna, de ha nem hagyom abba, és végig nyomom a 6 számjegyet, majd az INFO gombnak megfelelőt. (Megkerestem a képét a NET-en) akkor sem lép be.
Van valakinek ötlete, vagy más kódja?
Előre is köszönöm!
T.
Tisztelt Kollégák!
Egy kastélyszálló TMK-sa vagyok, ahol nagy számban üzemelnek még ilyen TV-k. A készülékek kb. hat évesek és egy viszonylag egyszerű hibával kezdenek elromlani. Nevezetesen, szétrobban a sortáp szűrőkondenzátora (47uF 160V). Ezután megszakad a 2,2 ohmos védőellenállás.
Eddig 5 db készülék romlott el így. Más hiba nem található a készülékekben. Kondit és az ellenállást kicserélve, pár nap működés után, ugyanaz a jelenség mindegyik készüléknél. Többféle gyártású kondit is kipróbáltam, egyik sem bírta tovább. Amikor a készülék működi minden feszültség rendben van a tápban. (A sortáp feszültsége 110 volt). Nem tudom mire véljem a dolgot, mert, hogy az eredeti kiszáradt, vagy zárlatos lett, ezt megértem, de mi van az újakkal? Ha nem kap váltófeszültséget, nem kap túlfeszültséget és még a polaritás is rendben, akkor mitől robbannak fel? Szerintem a táp nem "fut meg", mert más alkatrész nem megy tönkre.
Valakinek van ötlete?
Előre is köszönöm a válaszokat.
laszloferke
Üdv!cp90 sasszi,készülék hibátlanul működik,távval 3-4 alkalommal kikapcsolom stand by-ba,egyszer csak kikapcsolom ismét távval és készenlét helyett a led nem világít,a készülék pedig csak sípol hasonló módon mintha a sorvégfok zárlatos lenne.kb.20-ik próbálkozásra vagy sem, a hálózati kapcsolóval kapcsolgatva lesz készenlét és ismét be lehet kapcsolni a készüléket.Táp primer oldalán elko csere,össz 1n4148 dióda csere,szekunder oldali elkok csere,optocsatoló csere,sorvégtranyó,táp bu csere,és még mindig vagy indul vagy sem.Ebben szeretnék tanácsot kérni,vagy ha esetleg valakinek volt hasonló hibája le írná mit nézzek át a készenléti áramkörben.
Üdv. Mindenkinek!
Ehhez a tv hez nagy valószínűséggel eprom tartalom kellene. Táp hibája kijavítva mégsem indul,csak periódikusan rá rá próbál a háttérfény is fel fel villan.
Esetleg,ha valami más tapasztalat van valakinek,szivesen tanulnánk.
:help:
