Jó napot kivánok.
Rég nem jártam már már a tanya joldalán sajnos ,de most kellene egy kis segitség,lányom tv jén elromlott a táv a probléma hogy a tv az Csebe van a lányommal eggyüttnemtudom hol lehetne megnézni a kódját,mert hozzá hasonló pult van csak az a kérdes fogja e vinni.
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Tisztelt Kollégák!
A fenti készüléknek a következő hibája van: bekapcsoláskor egy darabig van kép, néhány másodperc és leáll, a power led villog kb. másodpercenként 2-t. A táp és a sortrafó környékén a kondikat kimértem esr-re, amit kellett, cseréltem (kb. 5-6 kondin a megengedett esr 2-3-szorosa volt), a hiba továbbra is fennáll. A táp terhelve 99 V volt, ezt lejjebb állítottam, 95 V-ra, így is megvan a hiba. Néha nem ezt csinálja, hanem elindul és üzem közben elkezd kerregni a sorvég, van, amikor ezt abbahagyja, egy idő után szintén villogó led. Melegedést, zárlatot nem tapasztaltam. A táp jó, 60 W-os izzóval próbáltam. Mi lehet még a hiba oka?
Tisztelettel:
Horváth József
Tisztelt Kollégák!
A fennti készülék eeprom tartalmára lenne szükségem ha valaki lenne szives segíteni.
A tulaj belepiszkált a szervízmenübe, elállította az opciókat és a TV behalt. Most csak annyit csinál, hogy beindul és csak halvány kék háttérfény van, sem kép sem hang és az OSD is hiányzik. A távra nem válaszol, ha lenyomok egy gombot a led pirosan villog és ennyi. Próbáltam üres memóriával, de azzal sem indul el.
Előre is köszi a segítséget.
