Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Sziasztok! Fenti készülék trafóhibás. Kombinált trafó, sortrafó egyben táp is. Képcső egyfókuszú, 29"-os. Hátlapról és trafóról is hiányzik a címke. Képcsövön szerepel készüléktipus. EME2 sassys, W76ESF031X44 tip. képcső. Talált doksi szerint 29"-os csőhöz 8204 000 73321 trafó dukál. Csak lengyel lapon találtam kép nélkül, 274ZL. Doksi szerint 25 és 28"-os képcsőhöz HR8457 jár. Nekem van 8457-en kívül 13929014 és 13929015(hr8864 és8866)is,ezek 2fókuszosak, úgy tudom ezek is eme2-ből valók. Kérdezni szerném: csak 8204 000 7321 trafóval van szerelve a W76ESF031X44-es képcsővel szerelt változat? Köszönöm István
sziasztok.a multkor úgy örültem hogy sikerült megcsinálnom ezt a nagy dögöt.most meg elment a fókusza,természetesen duplafókuszos.szerintetek képcsöves lett vagy a sortrafó döglődik?a sortrafóra ez van írva:38816 v9506 dc.
Egy eprom tartalmat keresnék ezen készülékhez.
Ha valaki tudna küldeni megköszönném.
