Ezzel a philips tvével akadtam el, elsőnek működött egy egész napot hibátlanul, de most egy negyed óra vagy fél óra múlva elsötétül, és a tetején színes csikok jelennek meg. Kikapcsolás és újra inditás után megint megy egy ideig. Most még azt furcsálom hogy 140v helyett csak 126V van, ez miatt csinál hajta, de ha jól is mükődik akkor is ennyi a feszültség. Átnéztem a forumot, de amit ott írtak 47uf, és a BC tranzisztorokról azokat kicseréltem, de a hiba megmaradt.
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
a modul a V4-es változat LJ92-01337 felirat van rajta. állandóan kinyírja a Q5011 és Q5013-as FETeket, méghozzá úgy, hogy a gate-re nem üt át, csak a D-S között van zárlatban, mintha a dioda volna zárlatos. letöltöttem a philips pdp 2k5 repair manualt meg a többit, de sajnos ott meg van a képe a V4-nek de nincs a kapcsolási rajz. letöltöttem a samsung SM-eket is de ott sem boldogultam . ha valakinek meg van csak a modulnak a rajza legyen szíves töltse fel. még jobb volna ha már valakinek sikerűlt megoldaina ezt a problemát és ezt megosztaná velünk. a tápegység feszűltségei kifogástalanok.
üdv. zoli
Tisztekletem mindenkinek!
Egy philips TV rajzát keresném. Típusa: 32pw8651/12. Jelenség: elindítva, hallani, hogy a táp fel felpörög, de lefullad. A sorvégfok tranzisztor 2 lábával párhuzamosan van egy nagyfeszültségű kondi, ami megégett. Sajnos így nem tudom milyen étrtékű lehetett.
Egy táprajz sokat segítene.
Előre is köszönöm.
