PHILIPS FC8136-01 VACUUM CLEANER
HOOVER - SERVICE MANUAL
989.7 KB
HOOVER
PHILIPS FC8136-01 VACUUM CLEANER service manual (1st page)
Preview of PHILIPS FC8136-01 VACUUM CLEANER [1st page]
PHILIPS FC8136-01 VACUUM CLEANER service manual (2nd page)
Preview of PHILIPS FC8136-01 VACUUM CLEANER [2nd page]
    PHILIPS FC-813601 CLEANER FC813601 VACUUM FC 813601 FC8136 01 FC8136-01
Relevant HOOVER forum topics:
Philips-Whirlpool ADG-622 mosogatógép
Sziasztok! A címben szereplő mosogatógép az anyós-jelöltem konyhájában lustálkodik. Nekem ugyan nincs túl nagy tapasztalatom a háztartási gépek javításában (bár a saját mosogatógépünk már megjavítottam egyszer) de szerelőre fordítható pénz híján kénytelenek velem is beérni. A probléma látszólag egyszerű: mosás után foltosak maradnak az elmosott eszközök (maga a gép is). Só van benne, közepesről maximálisra átállítva az adagolást sem változott a helyzet. Ötlete valakinek?
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips FC8132/01 porszívó alkatrészt keresnék
Nem hiszek ennek a résznek a műanyag hegesztésében, úgyhogy komplett dobozt keresek hozzá. Ez egy jóbarátom porszívója.
A képen látszik milyen szépen össze van törve.
Pityesz
Philips Saeco GranBaristo nem kapcsol be készenlét ok resetelni kellene megoldva
Sziasztok ezen a gépen csak készenlét van nem hajlandó bekapcsolni érintő kijelző jó szervizbe betudok lépni bluetottal rá tudok csatlakozni de nem kapcsol be a pover gombra lehet hogy gyerekzaron van?hogyan lehetne resetelni hogy gyárirol induljon.
