Szép napot ! A fent említett kéri a vízkő eltávolító programot. Viszont a tejtartó hiányában a program nem indul. Hiányolja, az ebben profik véleményét kérdem, hogyan lehet egyszerűen megoldani a gondot. Mivel a tejtartóhoz tartozó " csonkok " is hiányoznak. Amik a programhoz tartozó mikrokapcsolókat, kacsolnák. Tudom legegyszerűbb lenne venni hozzá, tartály van is, potom 10 ezerért de tető nincs. A lényeg pedig az lenne. Köszönöm a figyelmet !
Hope I've selected the right forum, I don't speak Hungarian!
I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack).
I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters.
I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB.
Can anyone suggest a value for R20 please?
Sziasztok ezen a gépen csak készenlét van nem hajlandó bekapcsolni érintő kijelző jó szervizbe betudok lépni bluetottal rá tudok csatlakozni de nem kapcsol be a pover gombra lehet hogy gyerekzaron van?hogyan lehetne resetelni hogy gyárirol induljon.
Szevasztok!
Vásároltam egy Philips Senseo kávépárnás kávéfőzőt. Egyetlen bajom van vele, hogy egyszemélyes kávét nem tudok vele csinálni. Túl sok vizet ad a 7 gr kávéhoz. Ezt szeretném megváltoztatni. Sikerült letöltenem a gép szevíz könyvét, de abban a vízszivattyúhoz csak egy "vezérlőegység" csatlakozik. Mielőtt szétszedném, érdeklődnék, foglalkozott e már valamelyikőtök hasonló géppel? Pontosabban az érdekelne, hogy milyen időkapcsoló van a vezérlőegységben? Egyszerű RC tag, vagy valamilyen PIC. Bár az utóbbi sem lenne gond, ha vissza lehet olvasni a tartalmát. Ebben kérném a segítségeteket, mert feleslegesen nem szeretném szétbontani.
Üdv: Gyula
