PHILIPS HD7822-60B COFFEE MAKER SENSEO
COFFEE-MACHINE - SERVICE MANUAL
356.3 KB
COFFEE-MACHINE
PHILIPS HD7822-60B COFFEE MAKER SENSEO service manual (1st page)
Preview of PHILIPS HD7822-60B COFFEE MAKER SENSEO [1st page]
PHILIPS HD7822-60B COFFEE MAKER SENSEO service manual (2nd page)
Preview of PHILIPS HD7822-60B COFFEE MAKER SENSEO [2nd page]
    PHILIPS HD-782260B COFFEE MAKER SENSEO HD782260B HD 782260 HD7822 60B HD7822-60B
Relevant COFFEE-MACHINE forum topics:
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HR1500A robotgép motor (megszakadt) megoldva :D
Sziasztok! Ilyet be lehet szerezni szerintetek? :( Meg van szakadva, még 200MOhm-os mérésnél sincs semmi életjel :( Köszönöm! Üdv: Pityesz
Philips GC9220 gőzállomásos vasaló kazán hőfok érzékelő értéke
Van egy ilyen gőzállomásunk. Nem termeli a gőzt, pontosabban csak alig gőzöl. Fűtést bekapcsolja pár másodpercre majd le. Első körben, még meleg állapotban megmértem a hőfok érzékelő (NTC) ellenállást, 123 kOhm körülit mértem. Majd mikor kihűlt újra megmértem, de már szakadást mutat.. Hosszas kutakodás után megtaláltam milyen kell bele, de konkrét értéket nem adnak meg sehol, még a szerviz manuálban sem, csak annyit, hogy 10-100 kOhm között van.
Itt látható hogy néz ki maga az érzékelő:
https://tr.ifixit.com/Guide/Philips+Pressurised+Steam+Generator+Iron+GC8220+and+Similar+Models%27+Temperature+Sensor+(NTC+Thermistor)+Replacement/95767#s177282
Esetleg valaki nem szerelt mostanában ilyen gépet?
Ilyen egyébként, de sehol sem rendelhető:
https://ersatzteildirect.de/de/Philips-Thermistor-fuer-GC9220-GC9230-GC9235-GC9245::6389.html
Üdv.: nils
Philips FC8132/01 porszívó alkatrészt keresnék
Nem hiszek ennek a résznek a műanyag hegesztésében, úgyhogy komplett dobozt keresek hozzá. Ez egy jóbarátom porszívója.
A képen látszik milyen szépen össze van törve.
Pityesz
