PHILIPS HQ7890 SHAVER
HOUSEHOLD - SERVICE MANUAL
215.6 KB
HOUSEHOLD
PHILIPS HQ7890 SHAVER service manual (1st page)
Preview of PHILIPS HQ7890 SHAVER [1st page]
PHILIPS HQ7890 SHAVER service manual (2nd page)
Preview of PHILIPS HQ7890 SHAVER [2nd page]
    PHILIPS HQ-7890 HQ7890 SHAVER HQ 7890
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips EP2221 automata kávéfőző
Olyan problémám lenne, a tárgybéli kávéfőzővel, ami alapvetően működőképes, de nem elég erős a főzött kávé és a főzés után is a zacc nem akar összeállni pogácsává csak ilyen folyós/pépes masszaként ürül ki a főzőegységből. Ha külön adagolom be a kávét a saját mérőkanalával akkor remekül működik. Próbáltam az őrlési finomságon is állítani, de nem hozott változást. Így arra a következtetésre jutottam hogy esetleg kevés a darált kávé mennyisége. Azt tudni kell hogy daráló motort kellett rajta cserélnem mert az előző gazdájánál tönkrement a daráló motorja. Valamit esetleg nem jól raktam össze vagy okosítani kell rajta?
Köszönöm előre is ha tud valaki segíteni.
üdv,
esaman
Philips FC8132/01 porszívó alkatrészt keresnék
Nem hiszek ennek a résznek a műanyag hegesztésében, úgyhogy komplett dobozt keresek hozzá. Ez egy jóbarátom porszívója.
A képen látszik milyen szépen össze van törve.
Pityesz
philips fc9016 porszívó nem indul, a feszültség leesik.
Sziasztok! A fent nevetett porszívó "philips fc9016 típus" nem kapcsol be. A panelon ellenőriztem a bejövő feszültséget. Amikor a kapcsoló kikapcsolt állapotban van, akkor mérhető a a bejövő 230 V, de bekapcsolás után nem mérhető semmi. Van rajta számomra egy ismeretlen félvezető. Segítségeteket előre is köszönöm. Alfonz
