PHILIPS HQ8830 SENSOTEC SHAVER
HOUSEHOLD - SERVICE MANUAL
266.0 KB
HOUSEHOLD
PHILIPS HQ8830 SENSOTEC SHAVER service manual (1st page)
Preview of PHILIPS HQ8830 SENSOTEC SHAVER [1st page]
PHILIPS HQ8830 SENSOTEC SHAVER service manual (2nd page)
Preview of PHILIPS HQ8830 SENSOTEC SHAVER [2nd page]
    PHILIPS HQ-8830 SHAVER HQ8830 SENSOTEC HQ 8830
philips scd505-bébicsöz nem találja a jelet
Udv!!! Kaptam az egyik ismerösömtöl egy "bébicsözt"-de nem találja a vevö az ado jelét-vajon most melyik lesz a hibás???? Ha esetleg valaki találkozott ehhez hasonlo problémával szivesen várnám a segítségét!!! Elöre is köszönöm!!! Stanley
Philips gc558/30 gőzálvány klixon....
Lenne egy ilyen ketyere. A kazánon van egy klixon, szét van rohadva.
Ha áthidalom, megy a cucc.
https://www.youtube.com/watch?v=7f5DQYDBrQs
A video 8-9 percénél látszik, kb. ilyen állapotban van a kazán is.
Mit kéne oda rakni kb.?
Kösz
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HR1500A robotgép motor (megszakadt) megoldva :D
Sziasztok! Ilyet be lehet szerezni szerintetek? :( Meg van szakadva, még 200MOhm-os mérésnél sincs semmi életjel :( Köszönöm! Üdv: Pityesz
