PIONEER DV-343
VIDEO-DVD - SERVICE MANUAL
16.0 KB
PIONEER DV-343 service manual (1st page)
Preview of PIONEER DV-343 [1st page]
PIONEER DV-343 service manual (2nd page)
Preview of PIONEER DV-343 [2nd page]
    PIONEER DV-343 DV343 DV 343
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
AIWA FX7500 Video törött fogaskerék.
Tudna valaki infót adni, hogy honnan lehetne szerezni a fent említett videóhoz fogaskereket, amelyik a kuplungot hajtja, 3 darabba van törve.Szétszerelés előtt folyton bekapta szalagot, kazettát, azonnal kikapcsolt. Forrasztóval összeolvasztgattam, mostmár elindúl, hang jó, képet húzza ,a szalagot már nem tekeri be a kazettát is szépen kiadja, lejátszás közben kattog enyhe deformácio miatt, nem is egyenletesen jár. Csak működésre akartam bírni.
THOMSON VTH6400,VTH6410,VTH6420
A készülék kazettafészkében a jobboldali műanyag lap a rugónál eltörött.Sehol nem rendelhető.Bontásból nincs-e valakinek.A mechanika sok más gépben is megtalálható. D35 futómű.pl LG,AIWA,JVC készülékekben.A képe megtalálható: HQVideo VA15381 www.hqelektronik.hu/info/hu/va15381.html originál rendelési száma LG 4471R0006A GEAR ASSY RACK F/L,hq Köszönettel gzoli
AKAI VS-425(megoldva)
üdv:keresem ennek a videonak a táprajzát. A tanyán levő rajok nem tartalmazzák. Kösz,Bálint
