PIONEER XV-LX61DV RR3868 SM
VIDEO-DVD - SERVICE MANUAL
19.1 MB
PIONEER XV-LX61DV RR3868 SM service manual (1st page)
Preview of PIONEER XV-LX61DV RR3868 SM [1st page]
PIONEER XV-LX61DV RR3868 SM service manual (2nd page)
Preview of PIONEER XV-LX61DV RR3868 SM [2nd page]
    PIONEER XVLX-61DV RR-3868 XVLX61DV RR3868 XVLX 61 DV RR 3868 XV LX61DV XV-LX61DV
AKAI VS-425(megoldva)
üdv:keresem ennek a videonak a táprajzát. A tanyán levő rajok nem tartalmazzák. Kösz,Bálint
Sony SLV715 kép van hang nincsen..
Sziasztok Van egy Video magnóm a tipusa SONY SLV-715 a következő hibát produkálja a kazettát betéve elindul a lejátszás kép van hang nincsen a kijelzö nem számlál a kép kb 2mp enként elmegy majd újra van kép és a traking led villog folyamtosan ,ha valakinek lenne ötlete hogy mi lehet a baja ,fejet megtisztogattam de semmi eredmény más ötletem most nincsen táp rendben van elkók jók a feszültségek meg vannak ...
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
kamera intercom
Viedeórendszerhez keresek Intercom kapcsolási rajzot és ötleteket 3 kamera és a videókeverő közé, mindenki halljon mindenkit és beszélni is tudjon ,ha kell szelektálni is lehessen
