Hi, my SAMSUNG UE40D5000 tv doesn' t work anymore. The red led light indicating that the tv is plugged is not powered when I plug in the tv. The original power board modem is BN44-00473B. I have checked the voltage on the connector to the mother board of the tv, and it was 0 instead of 5.3V or 13V on the different pins, with the fuse still working and no obvious overheated part on the power board and no bulging capacitor seen neither.
I have then changed the power board with a used one bought on ebay, which model BN44-00473A is said to be compatible. It has then worked perfectly 2 days until yesterday. This morning I had to move a little bit the tv, what I did very gently, and got really disappointed as I plugged it and didn't see the red led light on anymore.
Since this morning, the power board seems to be broken once more ( I have moved from my original flat 1 week ago and don't have a multimeter to check once more that the fuse is ok and what are the voltage on the connector to the mother board )
I am wondering if this new power board failure is just bad luck, 2 days after receiving this other power board circuit ( that is a used unit, not brand new) or if the mother board could have damaged it. In the first case I would send the power board back to the seller, otherwise I will probably give up as I don't have time and skills to repair the tv.
My question is : do you think the mother board or another unit connected to it, can damage the power board ?
Thanks for your help and answers !
Maint keresek egy Philips LCD-hez.
A lapos típusa Philips 32PFL3605/12, a main 715G3786-M1A-000-004X, a display LG LC320WUY.
Jani
Küzdök eme tv készülékkel... sajnos rajz nincs, viszont tele repedt forrasztással az annál inkább...
A bele emlékeztet a Grundig bélésre, de az istenek nem ugrik be melyik.
Sajnos meg akadtam...
Primer, szekunder oldal rendben találtam, de nem jelenti azt hogy jó is, sorvég jónak tűnik, és még sem működik....
Szóval a kérdésem az lenne hogy van valami ami felett elsiklottam?
Rajzom sajnos nincs kép van....
Feszültségeket mértem, de semmi feszültség nem jön a táp szekunder oldalon,
illetve az "1" lábon van 1,2V ami nagyon erőteljesen pulzál, a primer oldalon puffer kondin 309V van jelen.
Ha van valaki köztetek aki már találkozott eme készülékkel kérem segítsen!
Köszönettel Istva78
Üdv Istvan78
Sziasztok! Szerintetek is t-con probléma a képeken látható jelenség? A kép több órás üzem közben jelentkezett és konstans. Se hideg, se meleg, se fizikai hatásokra (pl. lvds kábel mozgatása) nem reagál. Esetleg gamma korrektor, vagy main hiba? Előre is köszönöm! Z
