QSC RMX0007 BULLETINA
231.9 KB
Looking for similar qsc manual?
QSC RMX0007 BULLETINA service manual (1st page)
Preview of QSC RMX0007 BULLETINA [1st page]
QSC RMX0007 BULLETINA service manual (2nd page)
Preview of QSC RMX0007 BULLETINA [2nd page]
    QSC RMX-0007 RMX0007 RMX 0007
Radio problema
Sziasztok Van egy PHILIPS radiom az oreg Opelben es az aksi csere utan kodot ker az indulasnal,havalaki tud segiteni megkoszonom
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Orion HS280 hangváltó bekötése
Szervusztok! Kérdezem, hogy a csatolt ábrán (280-as felső ábrák) az LB sugárzóhoz tartozó elkó bekötése melyik ábrán helyes? Az eredeti panelon az LB1031-hez tartozó elkó úgy van szitázva, polarizálva és beültetve ahogy a 4Ohmos változat rajzán látható.
Onkyo TX-SR507 végfok hiba. MEGOLDVA!
Adott acímben szereplő házimozi erősítő amiben tönkre ment egy pár alkatrész.Ezek közül a 2sb1369-et nem kapok a hq elektronikánál (onnan szoktam rendelni). Abban kérem a helpet hogy ezt honnan tudnám beszerezni (nem horror áron), vagy ha van helyettesítője akkor annak típusát megköszönném. Találtam egy 2sb1370-et. Az adatok szerint ez is jó lehet...vagy nem?
Kicseréltem a meghatókat az MJE340/MJE350 párosra, a véget 2SC5200/2SA1943 párosra és még 2db 10A-es bizti aztán indult is. Mindenkinek nagyon köszönöm a segítséget!
Szép napot!
