Most került hozzám ez a rádió, hogy nem csinál semmit. Szétszedés után találtam két smd ellenállást, amik megvoltak szakadva, ezek cseréje után, most már bekapcsol. A hangot viszont nem lehet szabályozni, szétszedtem a potit, de el vannak görbülve az érintkezői. Honnan lehet ilyen szabályzót beszerezni, és mi ennek a hivatalos neve?
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Megoldás:
A fólia -nyákhoz rögzíttet végén lévő- sávjait elkezdtem böködni inzulinfecskendő tűjével, de vagy a fólia volt túl szívós, vagy én voltam béna, két tű is elhajlott anélkül, hogy bármi lyukat ütött volna. Kerestem hegyes normál tűt, fokával beleszúrtam egy parafadugóba, úgy már tudtam böködni a sávokat. Minden sávot háromszor böktem meg a hosszán haladva, 1mm-es távolságokban. A kijelző visszatért a sírból, olyan, mint új korában. Ennyi. :)
Sikerült felélesztenem egy Blaupunkt Sydney RCM 126 fejegységet, a kijelzőjén viszont csak a bal alsó sarok működik, a többi része nem látszik vagy félreműködik. Nem értek a kijelzőkhöz. Nyomogattam a szalagkábelt a két végén, nem változtatott semmin. A forrpontok is rendben vannak az egész NYÁKon.
Az autórádió belsejében viszont egy részen korrodált a NYÁK, a galvánfuratok elrohadására gyanakodtam, de kiméregetve úgy tűnik, minden vezetősáv rendben van. Mondjuk gyanús, hogy arról a környékről több vezetősáv is az előlapi panelhez vezet.
Szeretném megmenteni és használni a rádiót. Tudnátok segíteni, mit keressek, hogyan vizsgáljam a hibát?
Előre is köszönöm!
Épp egy Stealth Autotek xs 1500 típus erősítőt javítok végfok hibával,ami már kész is lenne,de a végfokot meghajtó 20pin ic is meghibásodott.Sajnos a gyártó lemarta az összes számot a felületéről így,javíthatatlanná téve a készüléket,nem beavatottak számára.
Tudnátok nekem felsorolni ilyen 20pin-es icket,ami végfokozat meghajtására szolgálnak,hátha az egyik hasonló vagy pont olyan lesz.Az áramköri felépítéséből kb ki lehet találni a bekötési pontjait,tehát ha megvan a típus,akkor össze lehetne hasonlítani.
Előre is köszi mindenkinek!
Az ic fizikai méretéről itt egy link:
https://www.google.hu/search?q=ic+20pin&safe=off&tbm=isch&source=iu&ictx=1&fir=j1xpk60MpsPsAM%253A%252CV05dqVe8V_YLrM%252C_&usg=__0vBJY7feKbnbTkRYW40EWVI3vIo%3D&sa=X&ved=0ahUKEwjp4qWKj83ZAhXLKlAKHZ30AEcQ9QEIKzAA#imgrc=_
