ROTEL RHT-10 SERVICE
2.3 MB
Looking for similar rotel manual?
ROTEL RHT-10 SERVICE service manual (1st page)
Preview of ROTEL RHT-10 SERVICE [1st page]
ROTEL RHT-10 SERVICE service manual (2nd page)
Preview of ROTEL RHT-10 SERVICE [2nd page]
    ROTEL RHT-10 RHT10 RHT 10
Rotel
Need circuit diagram Rotel RA1592
topic locked: insufficient topic title, please correct the topic title and write more detail of problem! - admin
Rotel RA-980BX equivalent transistors
Hi All,
I have a Rotel RA-980BX amp with a blown channel. I have sourced most of the transistors, but am struggling to find the other 4.
Part numbers as follow:
2SC3478
2SC4381
2SA1376
2SA1667
What would be suggested equivalents / suitable replacements?
Also, some advice, I suspect the bias pot to be bad. Based on the circuit, would you think that the bad bias pot would cause the drivers and outputs to blow? Any suggestion on modification to prevent this re-occurring?
Thanks
Regards,
Werner
Rotel RA1592 doesn't start
does not start up
Rotel RA1592 does not start up
When power is applied, nothing happens, no standby-LED, Can not get switched on
