Sziasztok! Keresek Samsung UE32F5000AW tv-hez talpat! Akinek van kérem jelezze itt, vagy a djhalasi@gmail.com email címen! Köszönöm!
Complaint was no display, confirmed and I saw
this series USA model is very prone to backlight failure, so
ordered (8) new strips. Opened up the TV, and am testing the old ones. So
far all the ones on the right side are lighting up ok,
the set of strips connected to them via the connector side with the plugs
are not lighting up at all, even when I supply power directly
to the pins on that side.
I took out a set of the new strips, connected them together and tested, and
they are doing the same thing...whats going on? Thought these were all in
parallel.
If I separate the strips, the one with the connector plug seems to not
light. I have not gone through all the
new ones yet to test. I suppose they could be defective but strange how all
the ones in the TV on that side are not lighting and the others are.
Anyone have an idea whats going on here?
Keresek Ltf320Ab01 típusú kijelzőt + le32a457 hangszóróit.
Előre is köszönöm!
Samsung J52A
Kb. 10-15 perc után lekapcsolja a csöveket.
Hang marad. Nagyfesz megy. Függőleges cserélve. Fűtés nem áll le.
Most ismét nekiesek , talán megtalálom mi az ami változik.
Van ebben valami védelem ami tílthatja a csöveket?
Némi ötlet jól jönne?
Üdv István
