Üdv mindenkinek, kaptam egy a fent nevezett tv-t Angliából, vettem hozzá távot nagyon ügyes kis készülék ám egyik reggelre megadta magát zárlatos lett a képcső mint utóbb egy szerelő ismerősnél járt a masina felülvizsgán, ha valaki tudna esetleg egy ilyen készülékhez illeszkedő képcsövet, kérem jelezze de ha komplett működő gép van az is érdekelne, a képcsövön talált adatok a következők: A33EKC02X11 eltérítő tekercsek ellenálása 14 Ohm és 4 Ohm.
Hello, We have a samsung TV type LE40A557P2F from which the view disappears once in a while, while the sound continues.The screen still shows some dark background, but that's all.
Also the indication of which input channel is used when changing from HDMi1->HDMI2 does not appear when this problem occurs.
Anybody has some tips what could be the cause?
Somebody can help me on the electronic schematics?
Complaint was no display, confirmed and I saw
this series USA model is very prone to backlight failure, so
ordered (8) new strips. Opened up the TV, and am testing the old ones. So
far all the ones on the right side are lighting up ok,
the set of strips connected to them via the connector side with the plugs
are not lighting up at all, even when I supply power directly
to the pins on that side.
I took out a set of the new strips, connected them together and tested, and
they are doing the same thing...whats going on? Thought these were all in
parallel.
If I separate the strips, the one with the connector plug seems to not
light. I have not gone through all the
new ones yet to test. I suppose they could be defective but strange how all
the ones in the TV on that side are not lighting and the others are.
Anyone have an idea whats going on here?
