Üdv Mindenkinek!
Van egy radio:VWZ2Z2R2863991 a sorozatszám.
Létezik kalkulátor vagy csak a prociból lehet
kiolvasni a kódot?
Köszi
Üdvözletem !
Philips Szervízes Mestert keresek , ha van közöttünk .
Segítséget szeretnék kérni , vagy egy ilyen eladó monitort keresek.
Öreg Tom
Original problem is no sub woofer output. Been through this one and recapped it and the common 2 burned 1K (R16/17)
resistors are replaced but the sub is still not responding. Volume control potentiometer is a common issue on these but
the L-R spkrs sound good.
Went by this webpage on the repair:
https://christopherbradshaw.net/The_Project_Bin/klipsch%20promedia%20subwoofer%20repair%20-%20page%201.html
On the schematic there is a sub-relay (sw101) powered by +V_HF line it
maybe is suppose to be +V_LF ? Without the relay coming on looks like the sub is disconnected.
The zeners (D03/04) that give +/- Vcc to the op amps seemed way off so I replaced them and the voltages seem much closer.
Theres also a sub-mute line on p104 to p101. Power supply shows the LF mute relay and interconnect diagram says it
gets fed from the LF amp. What is triggering the mute? I dont see a mute button anyplace.
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
