SONY BDP-BX2 BDP-S357 BDP-S360 BDP-S363 VER1.3
VIDEO-DVD - SERVICE MANUAL
5.6 MB
SONY BDP-BX2 BDP-S357 BDP-S360 BDP-S363 VER1.3 service manual (1st page)
Preview of SONY BDP-BX2 BDP-S357 BDP-S360 BDP-S363 VER1.3 [1st page]
SONY BDP-BX2 BDP-S357 BDP-S360 BDP-S363 VER1.3 service manual (2nd page)
Preview of SONY BDP-BX2 BDP-S357 BDP-S360 BDP-S363 VER1.3 [2nd page]
    SONY BDPBX-2 BDPBX2 BDPS357 BDPS360 BDPS363 BDPBX BDPS 357 360 363 BDP BX2 S357 S360 S363 BDP-BX2 BDP-S357 BDP-S360 BDP-S363
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY SLV-SE710N
Sziasztok! Segítségeteket szeretném kérni! Behoztak hozzám egy ilyen típusú videót,az a gondom vele,hogy a lejátszás fekete-fehér,és felvétel is,akár RF-ről-akár av-ról..a normákat már váltogattam,nem reagál,csak egy dolog,ami érdekes,hogy ha a menüben átállítom a normát mesecamra,akkor a régi felvételeket színesen játsza le,de felvenni így is csak fekete-fehérben vesz fel.... van valakinek valami ötlete,hogy mi lehet ez a hiba? Köszönöm a segítséget! Köszönettel:Péter
Sony slv-x57 javíthatatlan?
Sziasztok! Apum kitett magáért. Van egy címben szereplő video, azt mondták neki nem érdemes megjavítani, erre miszlikbe szedte :( Miért nem hallgat soha rám... Ki ismeri ezt a gépet? Netán tényleg egy gagyi gép és nem volt kár érte? Üdv: Pityesz
Sony SLV E177
Sziasztok! A fent nevezett videóval lenne gondom. Mégpedig az, hogy időszakosan nem veszi be a kazettát ill. nem is adja ki(ha véletlen bevette). A mechanika mozgató motorral sorosan van egy 33 ohm os ellenállat az tűzforró de annyira hogy körülötte már minden feketedik. A mechanikát tisztítottam, elvileg nem is szorul, viszont ha megmozdítom a motortengelyt akkor működik. Mi lehet a gondja? Segítségeteket köszönöm. Krisz
