SONY BVH-3000PS BVH-3100PS REPLACEABLE PARTS AND OPTIONAL FIXTURE 2
VIDEO-DVD - SERVICE MANUAL
3.6 MB
SONY BVH-3000PS BVH-3100PS REPLACEABLE PARTS AND OPTIONAL FIXTURE 2 service manual (1st page)
Preview of SONY BVH-3000PS BVH-3100PS REPLACEABLE PARTS AND OPTIONAL FIXTURE 2 [1st page]
SONY BVH-3000PS BVH-3100PS REPLACEABLE PARTS AND OPTIONAL FIXTURE 2 service manual (2nd page)
Preview of SONY BVH-3000PS BVH-3100PS REPLACEABLE PARTS AND OPTIONAL FIXTURE 2 [2nd page]
    SONY BVH-3000PS BVH-3100PS AND OPTIONAL FIXTURE BVH3000PS BVH3100PS BVH 3000 PS 3100 3000PS 3100PS
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrész!
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrészt honnan lehet beszerezni?
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony SLV-E780 táp
Üdv! Van nálam egy Sony videó. Nem indul a tápja, a szokásos katt-katt-katt másodpercenként. Kicseréltem benne az összes elkót, az optót, a feszültség referenciát, kínomban már a tápIC-t is, mindhiába. A rajz: http://kepfeltoltes.hu/view/091112/sony_www.kepfeltoltes.hu_.gif A pirossal jelölt helyeken leválasztottam az áramkört, hogy ne zavarjon be, a zöld alkatrészek cserélve. Műterhelés van a kimeneten. A bemeneten megvan az egyenirányított hálózati feszültség, a tápIC megkapja a névleges tápot (13V), a szekunder oldalon a kattogással szinkronban megjelenik a feszültség is arra a rövid időre, amíg egy impulzus lefut. Ellenállásokat végigmértem, mindegyik névleges. A bemeneti áramkorlátozó értéke 0.33 ohm, ezt nem tudom ellenőrizni, a műszerem nem ennyire pontosm, de az értéke kisebb mint 1 ohm, úgyhogy jónak feltételezem. Tudtok segíteni? Mit nézzek még ezen a szutykon? DM
SONY SLV-SX717E (megoldva)
Kellemes Karácsonyt Mester Urak! Most egy fent nevezett Videomagnó javításához kérnék segítséget, ötletet. A szalagvezető babákat -és egyéb mechanikai részeket- mozgató műanyag alkatrész egy helyen szétrepedt, a babákat nem tartja fixen, a mechanika összekuszálódik fűzés közben. Keresem tehát a mellékelt képen lévő alkatrészt! Egyenlőre nem leltem rá sehol. (két SONY gépet is szétszedtem, mindkettő SLV-típusú hifi gép, a háromban egyetlen egymásra hasonlító alkatrész sincs) Esetleg valakinek, esetleg valami beszerzési forrás? Köszönöm, előre is! Tibor
