A fenti kamerához keresek 1-871-287-12 másik szám FP-573 flat cable-t. Ez a kijelzőhöz megy és szakadt. Érdekel bontott, új, vagy beszerzési forrás!
A segítséget előre is köszönöm!
Leiszt Jani
Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Olyan gondom lenne a fent nevezett készülékkel, hogy amikor felvételt készítek akkor szakadozik a hang, ill. pixeles lesz a felvétel. De csak akkor ha a kamerát mozgatom ha egy pontra nézek vele akkor nem.
Mi lehet ez?
Üdv Sanyi
I'm new to these forums and don't speak Hungarian.
I found a partial service manual for Sony SELP1650 lens (the exploded diagram, and instructions for removing the focusing barrel).
Please could this be added to your service manuals download section.
Thanks for providing forum, and resources.
